First 3rd party development using ColourSpace Remote Control
Author Steve
Male
#1 | Posted: 4 Dec 2020 15:15 | Edited by: Steve
The first 3rd party application using the new 'Remote Control' capabilities of ColourSpace has just been announced, and allows JVC's auto-cal program to use ColourSpace for probe control, etc.
It means any probe that can be used with ColourSpace, including probe settings, presets, etc., can now be used with JVC auto-cal.
Really cool!
https://www.avsforum.com/threads/colourspace-cms-next-generation-calibration-thread.3049142/page-63#post-60297327
Author ulrichd
#2 | Posted: 30 Jan 2021 17:34
Steve,
I'm using Peter's tool to have ColourSpace do the readings for JVC's projector calibration software. I just want to make sure I've got ColourSpace set up right:
I've got the active probe set to my i1D3, the reference to my i1Pro2. I then have to set 'Probe Matching Active' on the Graph Options, or are remote controlled readings always using the currently configured probe calibration settings when doing readings?
Cheers,
Ulrich
Author Steve
Male
#3 | Posted: 30 Jan 2021 17:41
At present, the data sent to the 3rd party program is the raw measurement data, not probe matched, as within ColourSpace probe matching is a post-process.
We have this on our list of WIBNIs to look at.
Author ulrichd
#4 | Posted: 30 Jan 2021 23:21
Fair enough. Thanks for letting me know. Here's hoping that it will make it into one of the next builds. Would certainly make the calibration that much more accurate.
I would argue that if one has probe matching set up that the measurement data sent to a 3rd party program is the probe matched data. If that's not desired, simply clear the probe match settings. I think LightSpace worked that way (if I'm not mistaken).
Best regards,
Ulrich
Author Steve
Male
#5 | Posted: 30 Jan 2021 23:25
LightSpace doesn't have Post-Profile probe matching...
Author Steve
Male
#6 | Posted: 26 Feb 2021 17:50
At With the latest build, released today, the data sent to the 3rd party program will now follow the settings within ColourSpace for probe matching.
So if Probe Matching is active, the data sent will be with Probe Matching active.
Author ulrichd
#7 | Posted: 27 Feb 2021 00:43
Awesome! I shall endeavour to test it this weekend...
Best regards,
Ulrich
Author ulrichd
#8 | Posted: 28 Feb 2021 03:13
Unfortunately, I didn't get very far: I'm using a RadianceMini-3D as a TPG, but this latest build (v937) is causing it to behave most erratically... I had it set to output full frame. On the manual measure page I have all sliders linked. I only saw a pattern change in the range of 0-64, after that all values looked the same. Values above 250 actually changed the output to a smaller frame and every step until 255 shows a different colour (even though I have all sliders using the same value). Is this related to the patch scale changes you're working on? I have patch scale set at 0-255 (didn't touch this, so I assume it was set to this when it was still working in previous versions).
Ulrich
Author Light Illusion
Male
#9 | Posted: 28 Feb 2021 08:52
We'll look into it.
As per the info provided with the recent builds, there are likely to be bugs.
Author Omardris
#10 | Posted: 28 Feb 2021 11:14
The data transfer to the ADD-ON for JVC-AutoCal now also works correctly if the user activates the probe matching in ColourSpace.
So this problem is fixed - thank you very much.
Peter
Author Steve
Male
#11 | Posted: 28 Feb 2021 14:52
We have found the Lumagen issue, and should be fixed in the next build.
That may be later today, or tomorrow.
Author ulrichd
#12 | Posted: 28 Feb 2021 16:15
Steve,
sounds good. Thanks for looking into it, and the great support!
Peter,
thanks for the confirmation!
Ulrich
Author Citation4444
#13 | Posted: 28 Feb 2021 16:33
Thanks, Steve. I was having the identical issues with Radiance Pro.
Male
#14 | Posted: 28 Feb 2021 19:04
A new build has just been released, that should have a fix for the Lumagen.
I have NOT tested the fix, as it's Sunday...
Members - 1 [ LeFric ]
Guests - 312 / Members - 0
