Is the i1 Display Pro probe an X-Rite discontinued product?
Author carles
#1 | Posted: 13 Mar 2023 17:49
Hi to All,
I'm searching this probe in my local dealers, and I'm only finding the Calibrite ColorChecker PRO and PLUS. Does the ColorChecker Plus work with ColourSpace INF? And will work fine for calibrate HDR displays?
As diferent option there is the SpyderX, is that probe able to calibrate for HDR or SDR only?
Many Thanks,
Carles
Author Steve
Male
#2 | Posted: 13 Mar 2023 19:01
X-Rite no longer sell hardware directly.
And yes, the Calibrite ColorChecker Pro and Plus are the same hardware.
Also, the SpyderX has basically the same capabilities as the i1Display Pro.
We use the SpyderX a fair bit ourselves.
Author carles
#3 | Posted: 14 Mar 2023 13:36
Many thanks for the answers!
Guests - 192 / Members - 0
