Hi, I'm trying out Lightspace LTE to hupefully get a better calibrated screen. My calibration level is beginner and therefore I would really appreciate some assistance.
My setup:
Eizo CG248-4K
i1 Display Pro Rev B. Retail
BM Intensity Pro 4K
TPG Davinci Resolve (and some testing with the internal Eizo Patches aswell)
Davinci Resolve is outputting video levels and the monitor is expecting video levels aswell (Eizo calls it limited input range)
The BarsandBlack Cal Image shows up as expected on the screen.
Yesterday I spend a day fiddling with some settings, after some really weird results doing 2 or 3 Display Characterization's I decided I might spend my time better testing some quick profiles first.
Here is my best result so far:
Pre Profile
https://www.lightillusion.com/forums/shared_files/storage/Profiles/2020-10-01equickzprofile.pdfPost Profile
https://www.lightillusion.com/forums/shared_files/storage/Profiles/2020-10-01qquicktprofile.pdfTo me Grey Scale Delta-E, Delta-E Distribution and Clip still look pretty bad. I'm a right or is it not sa bad?
I set the peak luma to approx 100 nits with the Display Controls\Brightness slider
With this brightness my blacklevel is approx 0.1100 nits.
When I unplug the signal or switch to a signal with no input, the black level remains approx 0.1100 nits.
When the screen is turned off the i1 Pro reads 0.0047 nits.
Here is an image of my probe settings:
Both the Resolve patches and Eizo internal patches gave more or less a similar profiling result.
Any tips what to change for a new try with full Display Characterization?
