csv of patches should also use the semicolon as separator
Author erazortt
#1 | Posted: 8 Jan 2022 13:05
Using non-english MS Excel will save cvs with semicolons instead of commas as separators. These cannot be opended and must be manually edited.
Author Steve
Male
#2 | Posted: 9 Jan 2022 16:16
Please remember that CSV files are Comma Separated Values, which follows a standard:
Data, a comma, data, a comma, etc.
It is a set standard specification.
You can change the default list separator for saving Excel files as text (. csv)
  • File > Options > Advanced > Editing options > Use system separators.
  • Set to comma as needed.
Max. ever online: 12 [12 Jan 2022 15:04]
Guests - 12 / Members - 0
