Colorimetry Research Probes & ColourSpace
Author Steve
Male
#1 | Posted: 20 Jan 2022 16:09
Light Illusion has been working with CR probes since they were first released.
Initially with LightSpace, and now with ColourSpace.
Thanks to a pain-in-the-a** Italian (hi Miki ), we have discovered that our original CR integration has not kept pace with CR probe development.
This means that at present the time take to take a measurement with a CR probe (specifically the CR-100) with ColourSpace is not as quick as it could/should be.
(The measurement time is correct, but parsing the data into ColourSpace is not... and measurement accuracy is not affected.)
We will be completely re-doing CR probe integration as soon as we can, to gain the maximum capabilities, and speed, from the CR probes.
We cannot provide a timescale on this at this time, but aim to have the new integration development done as quickly as we can.
Author Anger
Male
#2 | Posted: 20 Jan 2022 16:34
Thank you for the kind words Steve! LOL It's always a pleasure to help you getting things better. Just doing my part...
Please be quick as I'm waiting to test the new integration to buy a CR-100! Ah! And don't forget to ask CR for the API/SDK of the WiFi Box for its subsequent integration! Thanks!
Miki
Author Htnut
#3 | Posted: 22 Jan 2022 08:26
I am struggling to understand what the consequences of this issue is.
Is it just speed or or is it accuracy?
Author Steve
Male
#4 | Posted: 22 Jan 2022 08:55
As it says above "(The measurement time is correct, but parsing the data into ColourSpace is not... and measurement accuracy is not affected.)"
Author Htnut
#5 | Posted: 22 Jan 2022 08:59
Please explain exactly what is not working. If it not speed or accuracy then how does it affect a user's
Author Steve
Male
#6 | Posted: 22 Jan 2022 09:00
As is says above "This means that at present the time take to take a measurement with a CR probe (specifically the CR-100) with ColourSpace is not as quick as it could/should be."
Author Htnut
#7 | Posted: 22 Jan 2022 09:19
So it is just speed?
Author Steve
Male
#8 | Posted: 22 Jan 2022 10:49
That is indeed what is stated in the above post.
Guests - 192 / Members - 0
